Cisco Nexus 7009 external power supply fan does not rotate but air is detected
dscorpa
The fan of the external power supply of the Cisco Nexus 7009 does not rotate, but air is detected.
At command level it indicates that everything is fine and even the lights appear without alarm but the fan does not rotate and verified in another Cisco Nexus 7009 that has the same behavior so this all ok , but I would need to know the reason why the fan that is seen from the outside does not rotate
Fan:
Fan Model Hw Status
Fan1(sys_fan1) N7K-C7009-FAN 1.0 Ok
Fan_in_PS1 -- -- Ok
Fan_in_PS2 -- -- Ok
Fan Zone Speed: Zone 1: 0x6f Zone 2: 0x30 Zone 3: 0x30 Zone 4: 0x30
Best regards
Daniel
Javier Acuña
hello mate, in many cases the fans work with two speeds, the cisco 7009 devices have two fans, one for daily work and another that will be activated when the working temperature passes around 21 degrees, then I send you an image of the device, remember to rate this answer as this motivates you to continue supporting
