Showing results forĀ
Search instead forĀ
Did you mean:Ā
C9300L-48P-4G: Switch reloading due to thermal temperature violation
ReneIversen
We are experiencing that a switch is reloading due to error: Hotspot temperature is above maximum limit and will be immediately shut down.
But the temperatures on the switch are normal.
First we see multiple: 2042: 002048: Mar 4 19:27:52.273: Switch 1 R0/0: cmand: Hotspot temperature has exceeded RED threshold. Switch will shutdown soon.
Then we get: 2046: 002052: Mar 4 19:28:12.454: Switch 1: Hotspot temperature is above maximum limit and will be immediately shut down.
After this the switch will reload.
We have Tried with different Software versions, 17.3.5, 17.12.4 and 17.15.2.
Has anyone had same issue, and found a software version that is working without the bug?
I have found bug: CSCwf47107   that looks to be same problem, but there is no resolution.
RenƩ
@ReneIversen wrote:
03/04/2025 00:14:37 %NYQ-1-PLATFORM_COLD_ERROR : OBFL TEMP COLD ERROR : hotspot -171
03/06/2025 05:15:15 %NYQ-1-PLATFORM_HOT_ERROR  : OBFL TEMP HOT ERROR  : hotspot 143
Organize for the switch to be RMAed.
The internal temperature sensor is faulty.
Look at the output above:  Sensor detects the temperature to be -171C and the next day is 143C.
6 Replies 6
Leo Laohoo
Post the complete output to the command "sh log on switch active message details".
ReneIversen
Hi Leo :
Here is the output.
CHDPU1-SWCH0012#sh log on switch active message detail
ERROR MESSAGE SUMMARY INFORMATION
MM/DD/YYYY HH:MM:SS Facility-Sev-Name | Count | Persistence Flag
03/06/2025 02:10:53 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : 46 : LAST : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
01/31/2025 16:41:16 %NYQ-1-PLATFORM_HOT_ERROR : 34 : FIRST : OBFL TEMP HOT ERROR : hotspot 143
03/03/2025 16:10:23 %NYQ-1-PLATFORM_FEP_POWER_OFF : 6 : LAST : OBFL FEP POWER OFF: B
03/06/2025 02:10:53 %NYQ-2-PLATFORM_PSFAN_PRESENT : 42 : LAST : OBFL PS-FAN PRESENT : FEP fan PS-1
01/31/2025 06:37:19 %NYQ-1-PLATFORM_COLD_ERROR : 29 : FIRST : OBFL TEMP COLD ERROR : hotspot -170
03/06/2025 02:07:44 %NYQ-3-PLATFORM_FEP_POWER_ON : 2 : LAST : OBFL FEP POWER ON: A
ERROR MESSAGE CONTINUOUS INFORMATION
03/01/2025 15:01:31 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/02/2025 10:02:56 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 192
03/02/2025 10:06:06 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/02/2025 10:06:06 %NYQ-1-PLATFORM_FEP_POWER_OFF : OBFL FEP POWER OFF: B
03/02/2025 10:06:07 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/02/2025 10:06:07 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/02/2025 16:37:11 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/02/2025 16:40:24 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/02/2025 16:40:24 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/02/2025 23:27:54 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/02/2025 23:31:05 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/02/2025 23:31:05 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/03/2025 00:53:24 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/03/2025 00:56:36 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/03/2025 00:56:36 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/03/2025 02:55:13 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/03/2025 02:58:27 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/03/2025 02:58:27 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/03/2025 11:28:54 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 144
03/03/2025 11:32:09 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/03/2025 11:32:09 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/03/2025 11:48:47 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/03/2025 11:52:00 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/03/2025 11:52:00 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/03/2025 16:06:49 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/03/2025 16:10:23 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/03/2025 16:10:23 %NYQ-1-PLATFORM_FEP_POWER_OFF : OBFL FEP POWER OFF: B
03/03/2025 16:10:24 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/03/2025 16:10:24 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/03/2025 17:32:29 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/03/2025 17:36:03 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/03/2025 17:36:03 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/03/2025 22:24:12 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/03/2025 22:27:46 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/03/2025 22:27:46 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/04/2025 02:10:46 %NYQ-3-PLATFORM_FEP_POWER_ON : OBFL FEP POWER ON: A
03/04/2025 02:10:46 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/04/2025 02:14:48 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/04/2025 02:14:48 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/04/2025 04:25:02 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 144
03/04/2025 04:28:35 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/04/2025 04:28:35 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/04/2025 20:27:10 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/04/2025 20:30:41 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/04/2025 20:30:41 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/05/2025 14:05:21 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/05/2025 14:08:54 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/05/2025 14:08:54 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/06/2025 02:07:44 %NYQ-3-PLATFORM_FEP_POWER_ON : OBFL FEP POWER ON: A
03/06/2025 02:07:44 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/06/2025 02:10:53 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/06/2025 02:10:53 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/06/2025 02:42:17 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/06/2025 02:45:52 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/06/2025 02:45:52 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/06/2025 05:18:52 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/06/2025 05:18:52 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/06/2025 07:28:45 %NYQ-1-PLATFORM_HOT_ERROR : OBFL TEMP HOT ERROR : hotspot 143
03/06/2025 07:32:20 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
03/06/2025 07:32:20 %NYQ-1-PLATFORM_FEP_POWER_OFF : OBFL FEP POWER OFF: B
03/06/2025 07:32:21 %NYQ-2-PLATFORM_PSFAN_PRESENT : OBFL PS-FAN PRESENT : FEP fan PS-1
03/06/2025 07:32:21 %NYQ-2-PLATFORM_PSFAN_NOT_PRESENT : OBFL PS-FAN NOT PRESENT : FEP fan PS-2
CHDPU1-SWCH0012#
CHDPU1-SWCH0012#show env all
Sensor List: Environmental Monitoring
Sensor Location State Reading Range(min-max)
PS1 Vout 1 GOOD 56432 mV na
PS1 Vin 1 GOOD 242000 mV 90 - 264
PS1 CURin 1 GOOD 346 mA na
PS1 Curout 1 GOOD 1000 mA na
PS1 POWin 1 GOOD 66750 mW na
PS1 POWout 1 GOOD 55500 mW na
PS1 FAN 1 GOOD 3888 rpm na
PS2 Vout 1 NOT PRESENT 0 mV na
PS2 Vin 1 NOT PRESENT 0 mV 90 - 264
PS2 CURin 1 NOT PRESENT 0 mA na
PS2 CURout 1 NOT PRESENT 0 mA na
PS2 POWin 1 NOT PRESENT 0 mW na
PS2 POWout 1 NOT PRESENT 0 mW na
PS2 FAN 1 NOT PRESENT 0 rpm na
SYSTEM INLET 1 GREEN 28 Celsius 0 - 56
SYSTEM OUTLET 1 GREEN 34 Celsius 0 - 125
SYSTEM HOTSPOT 1 GREEN 47 Celsius 0 - 125
Switch FAN Speed State Airflow direction
1 1 5458 OK Front to Back
1 2 5458 OK Front to Back
1 3 5458 OK Front to Back
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A PWR-C1-715WAC-P DCC2652C1MR OK Good Good 715
1B Not Present
CHDPU1-SWCH0012#
Thank you Leo, I have created RMA for this switch.
/RenƩ
marce1000
@ReneIversen    >.... that looks to be same problem, but there is no resolution.
                            Yet the bug report : https://bst.cisco.com/bugsearch/bug/CSCwf47107?rfs=qvred
                            has a section with Known Fixed Release ,
  M.
Hi Marce1000
Yes i have tried but 17.12.4 and 17.15.2 that are on the Known Fixed Released list.
/RenƩ
