CSCuf25963 - PI1.2 Health Monitor is running, with an error/NMS Server is stopped
K D
I am hitting bug, where the nms service stops atleast twice in a week and and then come back after 10 mins.
Does ny one know when there will be a patch release for this issue?
Phillip Remaker
From the bug notes, it looks like version 2.0 and later will have the fix.
However, if the service stops and you have not changed the hotname/IP address from the original setup, this is probably not your bug.  You may want to open a case with the TAC.
If that is the case, follow the workaround instructions in the release note to update the information on the server.  (That is, from the root shell, update the file /opt/CSCOlumos/conf/messaging.properties with the correct IP address.)
Thanks Philip. Mine is not related to hostname ot Ip address change , but it nms service stops without a reasona nd comes back online after 10 mins.
Then perhaps it is not this bug.  You may need to open a TAC case.
