CSCul27686 - Nexus 5548P Interfaces may go down after upgrade and cannot be recovered
Marcin Zgola
Level 4
Level 4
Finally!!!!! I waisted almost 2 weeks dealing with that problem....
CCIE 18676
Rik Irvine
So Bug Fix CSCul27686 states interface issues in version 5.2(1)N1(6) or 6.0(2)N2(2) are fixed in versions 5.2(1)N1(7) and  5.2(1)N1(6.93).
Neither of the fixed versions are appearing as available for download. Surely I don't have to raise a TAC case to obtain them, do I?
Any help much apreeciated.
Rik
glmharled
Hi, does anyone knows if 6.0(2)N2(3) affected by this bug?
it's not mentioned in both affected and fixed-in version.. we're planning to upgrade to this version
Hi there,
It is shown as "resolved-in" this version;
Resolved Caveats in Cisco NX-OS Release 6.0(2)N2(3)
Table 9     Cisco NX-OS Release 6.0(2)N2(3) Resolved Caveats
Record Number
Resolved Caveat Headline
CSCuf90644
STP BPDUs sent with different MAC with peer-switch after upgrade.
CSCuh33604
MAC learning issue
CSCui47367
"shut/no shut" for vfc crashed device due to FWM hap reset.
CSCui79701
Config Sync / Verify Failed / Lock already taken by another session
CSCuj32483
LACP member ports stuck in I state.
CSCuj40011
Unexpectedly reloaded due to dhcp_snoop hap reset.
CSCuj56227
IGMP proxy reports might loop on the network.
CSCuj59439
vPC hap reset after peer-keepalive link comes up.
CSCuj92481
ISSU 6.0.2.N1.1 to 6.0.2.N2.2 free space below threshold.
CSCul05896
When switching from HSRP standby deletes HSRP VMAC from hardware.
CSCul20086
The snmpd process crash on Nexus tied to user permissions.
CSCul27686
After Upgrade Interface Down & Unrecoverable.
From;
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5500/sw/release/notes/6_02/Nexus5500_Release_Notes_6_02.html#wp492866
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
