Highlighted
Beginner
CSCve21378 - 2960x - Power Controller reports power Tstart error detected - 1
Hi guys,
Facing this issue too.
I issued below command only and it cleared the error. You have to first determine the minimum power required by the third party device drawing power from the switch. In my case it was hikvision cameras.
power inline consumption 9000
shut
no sh
3 REPLIES 3
Highlighted
VIP Mentor
Re: CSCve21378 - 2960x - Power Controller reports power Tstart error detected - 1
For not there is no work around or fix provided on that bug, you need to wait for TAC to fix this.
if this is effecting your production environment,i suggest to  reach Cisco TAC is quick way for the fix any short term.
BB
*** Rate All Helpful Responses ***
Highlighted
Beginner
Balaji,
POE error cleared for my case after limiting power consumption. I'll however wait for the fix.
Highlighted
VIP Mentor
thank you for your input, sure tac can contact you if you have raised case and fix available(upgrade or work around);.
BB
