I faced the situations of CSCvg59274 whenever I exchange FAN of Cisco ASR9901(IOS XR6.4.1).
After exchanging FAN,I needed reboot Cisco ASR9901.
I found the article and it shows some workaround(seems not official).
http://www.belpia.com/workaround-for-cscvg59274/
It says before you insert the FAN(FAN-0),unplug the another FAN(FAN-1).
And then insert the FAN-0 first.FAN-1 the next.
I did the same thing the article showed at lab and I could exchange FAN without interupting the circuit.
Could you kindly give me some advice or opinion about it?
Thank you.
