Highlighted
Beginner
CSCvg76031 - IMP services stuck in starting state after fresh install/upgrade
I am doing a PCD upgrade for the IMP servers and it cannot continue after the first server because the (PAWS) service is down amongst a few others on the primary.  Using the 12.5(1) latest upgrade file.
What is the fix for this Cisco?
17 REPLIES 17
Highlighted
Nat Beginner
Beginner
Re: CSCvg76031 - IMP services stuck in starting state after fresh install/upgrade
same issue here with a manul upgrade (no PCD)
many services stuck in starting mode with no possibility restart it properly..
any clue?
regards
Nat
Everyone's tags (3)
Highlighted
Beginner
I was told by TAC to try this on the IMP server, then restart server.
set replication-sync monitor disable
I am going to test this tomorrow. If you test earlier please let me know!
Highlighted
Beginner
Hi Michael,
Yes i was told the same from TAC.
and it works like a charm :) so great news. i already faced this issue twice on 2 different migrations...
Nat
Beginner
Don't forget to re-enable "replication-sync monitor" after the services are all started :)
Highlighted
Beginner
Hi guys,
It works for me. I was doing the upgrade from 11.5 to 12.0.
Thanks for the tip.
Highlighted
Beginner
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
If I was you I would consider the jump to go to 12.5.
12 is buggy. Cisco barely do any fixes for 12.0 and basically all future effort goes into 12.5.
Highlighted
Beginner
Needed to use this on a 11.5 SU3 to 12.5 SU1 upgrade. I didn't reboot the servers after applying the command, and they started all the services on their own. I'll still reboot though. Saved me a TAC call!
Highlighted
Beginner
Yep agreed. Looks like this is just generally a good idea after you upgrade.
Highlighted
Beginner
I have ran this command and it did not work for me.. Presence Engine still showing in starting state.  Version 12.51.11900-117. Anything else I can try?
Highlighted
@TracyLogan2685 Did you resolve your issue? I am running into the exact same issue you are on a fresh install.
Highlighted
Beginner
Hi Joe ,
Any luck with the service issue ? , i have run in to same issue as well .
Thilina
Highlighted
Beginner
Did you run the command and then reboot the IM&P server? Then wait about 5-10 minutes after it reboots.
Highlighted
Beginner
Hey mate , thanks.
Yeah , I already tried that. but no luck :(
Highlighted
Ended up having to open a TAC case. It was an issue where the server was built with the hostname capital letter, node name in lower case, and it caused issue with the hosts file. TAC had to get root access and issue a command to modify the host file.
Content for Community-Ad
FusionCharts will render here
