CSCvm95999 - Cisco IP Phone 8800 Series Arbitrary Script Injection Vulnerability
mcecilia
Hello team,
Are older versions also affected? For example sip88xx.12-1-1-12
joshua.gertig
Also curious about this. Does anyone know if 11.5 SU5 is affected?
joshua.gertig
FYI, our latest communication w/ TAC:
Thanks After some research the firmware Version 12.5(1)MN515 has not been released, however after checking I can see that according to some similar cases the DE team confirmed that version 12.5.1ES2  contains the fix. I am now in the process of publish for you the firmware, you will receive an email with a link on where to download the file.
Best regards,
