01-29-2021 03:25 AM
We have a 9300 running 16.12.4 (listed in the bug as a fixed release) with a standard port (not on an uplink module) where a redundant port-channel member link has it's port status LED lit amber, and nothing in the actual port status or logging under CLI suggests any sort of error. Would appreciate if anyone else can corroborate similar behaviour? Thanks.
01-29-2021 03:30 AM
Can you post the configuration of that ports ?
01-29-2021 03:34 AM
Ten ports in the etherchannel, all configured identically and pretty basic. The active ports appear to be working fine.
interface Port-channel11
switchport mode trunk
interface GigabitEthernet1/0/1
channel-group 11 mode active
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
01-29-2021 03:37 AM
Example corresponding ports from other side of port-channel, e.g. ports on both sides are all set to 'active';
interface GigabitEthernet5/0/47
channel-group 1 mode active
interface GigabitEthernet5/0/48
01-29-2021 04:09 AM - edited 01-29-2021 04:11 AM
Can you post below output from both the devices :
show etherchan 1 summary
show log - both switches
01-29-2021 04:18 AM
etherchannel summary on both switches showed 8 active ports as (P) participating and 2 ports as (H) as expected, including the one with the amber LED.
'sh log | i 2/0/5' where Gi2/0/5 is the port showing the amber LED just showed port up and port down events. Sorry I don't have the output but this is recollection from initial troubleshooting.
01-29-2021 05:36 AM
i would still insists to see the output below : (before we think of anything)
02-02-2021 03:15 AM
#show etherchannel 11 summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 11
Number of aggregators: 11
Group Port-channel Protocol Ports
11 Po11(SU) LACP Gi1/0/1(P) Gi1/0/2(P)
Gi1/0/3(P) Gi1/0/4(P)
Gi1/0/5(P) Gi2/0/1(P)
Gi2/0/2(P) Gi2/0/3(P)
Gi2/0/4(H) Gi2/0/5(H)
#show etherchannel 1 summary
d - default port
1 Po1(SU) LACP Gi1/0/47(P) Gi1/0/48(P)
Gi2/0/47(P) Gi2/0/48(P)
Gi3/0/47(P) Gi3/0/48(P)
Gi4/0/47(P) Gi4/0/48(H)
Gi5/0/47(P) Gi5/0/48(H)
02-02-2021 07:54 AM - edited 02-02-2021 07:54 AM
Looks good, when you get chance or maintenance window time, shut and no shut the Port-channel.
are you seen any Operational impact for now ?
