08-22-2021 04:32 PM
Hi, we are hitting this bug on a C9200L-24T-4X
fan is spinning, temps are fine, but we regularly we get a reported failure and then recovery as below
firmware is 17.03.03. are there any known fixed releases?
Cisco Bug Discussions
Aug 19 19:19:22.795 : %PLATFORM_THERMAL-6-FRU_FAN_RECOVERY: Switch 1: System fan 1 recovered to normal status
Aug 19 19:20:46.829 : %PLATFORM_THERMAL-1-FRU_FAN_FAILURE: Switch 1: System fan 1 failed
Aug 19 19:27:55.114 : %PLATFORM_THERMAL-6-FRU_FAN_RECOVERY: Switch 1: System fan 1 recovered to normal status
Aug 19 19:58:44.482 : %PLATFORM_THERMAL-1-FRU_FAN_FAILURE: Switch 1: System fan 1 failed
Aug 19 19:59:28.536 : %PLATFORM_THERMAL-6-FRU_FAN_RECOVERY: Switch 1: System fan 1 recovered to normal status
Aug 19 20:01:04.542 : %PLATFORM_THERMAL-1-FRU_FAN_FAILURE: Switch 1: System fan 1 failed
Aug 19 20:09:24.949 : %PLATFORM_THERMAL-6-FRU_FAN_RECOVERY: Switch 1: System fan 1 recovered to normal status
Aug 19 20:12:01.065 : %PLATFORM_THERMAL-1-FRU_FAN_FAILURE: Switch 1: System fan 1 failed
Aug 19 20:12:09.065 : %PLATFORM_THERMAL-6-FRU_FAN_RECOVERY: Switch 1: System fan 1 recovered to normal status
Aug 19 20:13:17.118 : %PLATFORM_THERMAL-1-FRU_FAN_FAILURE: Switch 1: System fan 1 failed
Aug 20 00:59:29.533 : %PLATFORM_THERMAL-6-FRU_FAN_RECOVERY: Switch 1: System fan 1 recovered to normal status
Aug 20 01:15:46.254 : %PLATFORM_THERMAL-1-FRU_FAN_FAILURE: Switch 1: System fan 1 failed
Aug 20 01:17:18.282 : %PLATFORM_THERMAL-6-FRU_FAN_RECOVERY: Switch 1: System fan 1 recovered to normal status
Aug 20 01:19:06.375 : %PLATFORM_THERMAL-1-FRU_FAN_FAILURE: Switch 1: System fan 1 failed
Aug 20 09:58:33.399 : %PLATFORM_THERMAL-6-FRU_FAN_RECOVERY: Switch 1: System fan 1 recovered to normal status
Aug 20 10:01:29.514 : %PLATFORM_THERMAL-1-FRU_FAN_FAILURE: Switch 1: System fan 1 failed
Aug 20 10:03:33.621 : %PLATFORM_THERMAL-6-FRU_FAN_RECOVERY: Switch 1: System fan 1 recovered to normal status
08-22-2021 07:08 PM
Get the fan replaced first.
If the same error message occurs after the fan is replaced then it could either be a switch issue or a BUG.
08-22-2021 07:12 PM
The answer is not "could be a bug". There is a bug, the bug ID is CSCvy10601
The fan is spinning while the error message shows the fan has failed.
We want to know which IOS has a fix.
10-25-2021 07:26 PM
Hello ryancisco01
Thank you very much for posting your concern, for this bug the fix will be in the train versions 17.7.x and 17.8.x, this bug is cosmetic so it does not affect the performance of the device since the FAN continues to work properly, therefore so a replacement is not necessary.
Best regards,
11-15-2021 06:33 AM
Do you have an ETA of release for 17.7.x and 17.8.x ?
