Error connecting to cluster machine
EUR
I'm receiving this warning, but on CLI with command clustercheck and clusterconfig->connstatus I haven't problem.
what means?
The Warning message is:
Error connecting to cluster machine hostname (Serial #: xxxx ) at IP x.x.x.x - Connection failure - [Errno 60] Operation timed out
Last message occurred 3 times between Mon Apr 30 11:36:22 2018 and Mon Apr 30 11:40:22 2018.
Error connecting to cluster machine hostname (Serial #: xxxxx) at IP x.x.x.x - Connection failure - [Errno 61] Connection refused
Last message occurred 2 times between Mon Apr 30 11:42:06 2018 and Mon Apr 30 11:42:07 2018.
Thank you
0 Replies 0
