Frequent drain of Connection Event - CSCuz86604
kyleharris
Beginner
Beginner
This bug is also manifesting itself on SF IPS on SSD version 6.2.x
We are hitting this bug too. ASA 5512-X version 9.7.1(4) and FMC 6.2.0 (build 362). Getting flurries of critical alerts almost every day, usually in the early hours of the morning.
6 Replies 6
kossuth78
Beginner
Beginner
Seen similar behavior of this bug on version 6.2.0.2 on a 5512x ASA running IOS version 9.7(1)8 with ASDM 7.8(1)150 running a virtual FMC.
ITWhiteRock
Beginner
Beginner
Has anyone tried the workaround listed in the bug search?
Workaround:
Switched the event storage to SSD that fixed the issue.
Command to switch event storage to SSD from the restricted shell would be:
> configure log-events-to-ramdisk disable
I did so in my particular situation documented above and yes it cleared the issue up.
