06-10-2015 08:24 AM - edited 03-20-2019 08:37 PM
I have a client running version 5.2(1)N1(8b) and wanted to know if this falls under the affected releases.
Known Nexus 5K affected releases:
Known Nexus 5K fixed releases:
CSCub38654 - N5K Switch hang/lock up may occur due to Leap second update https://tools.cisco.com/bugsearch/bug/CSCub38654
Solved! Go to Solution.
06-17-2015 01:36 AM
Our NX-OS versions are not on the list either but to play it safe were disabling NTP from 29th June to 1st July anyway ,if your that unsure TAC it
06-10-2015 02:27 PM
Hi no your clients version should not be effected by this bug
06-10-2015 02:35 PM
Thanks Mark. I listed the known affected and fixed releases based on the Cisco bugsearch result listed in the question but could not find my exact release. Do you have another source for my actual version 5.2(1)N1(8b) that you could reference?
06-11-2015 03:26 AM
Hi your client is on the safe harbour image the most recommended one in the train by Cisco , your image is from Nov 2014 the ones effected are a year before it , you will not get any more confirmation other than the bug release , out of all the releases only 2 were effected so it very unlikely there version is as the fix would generally be in newer releases , you can check the release notes caveat section for your version but i dont see any on the Cisco website for these releases
06-16-2015 10:47 AM
When I go to Cisco's bug search site and enter "leap second" and nexus 5596UP as a product, it doesn't have any reference to the specific version we 5.2(1)N1(8b). Here's the search results I do get:
I'm still not convinced my version is not affected. The ones higher are listed as fixed but no mention of this:
Known Fixed Releases: | (3) |
06-17-2015 01:36 AM
06-17-2015 11:48 AM
Mark,
We are doing the same, nice to see another person going this route. Thanks for the input.
Nitan
06-24-2015 07:08 AM
Hi!
I have a customer running the same version, 5.2(1)N1(8b) so we're gonna disable NTP as well.
Since we have two Nexus-switches we're configuring in a switch-profile.
However, I'm unable to remove the ntp server when I'm in config sync.
The negate command does not exist.
Nexus-1(config-sync-sp)# no ? cdp Configure CDP parameters class-map Configure a class map clock Clock feature Command to enable/disable features fex FEX configuration hardware Change hardware usage settings interface Configure interfaces ip Configure IP features ipv6 Configure IPv6 features lacp Configure LACP parameters logging Modify message logging facilities mac MAC configuration commands mac MAC mvr-config Enable IGMP MVR policy-map Configure a policy map port-channel Configure port channel parameters port-profile Configure a port-profile slot Configure a slot spanning-tree Spanning Tree Subsystem sync-peers Specify peers to whom configuration needs to be synced system System management commands vlan Vlan commands vpc Vpc wrr-queue Map traffic priority (CoS) values to L3 Multicast Queues
Do I just use conf t and remove the ntp server on both switches?
06-24-2015 07:23 AM
You can remove the config part and you can disable the NTP feature , that way NTP is not running at all on the Nexus
06-25-2015 12:08 AM
What do you mean, "remove the config part"?
Do I remove the ntp server x.x.x.x line in both switches or can I do something in config-sync?
06-25-2015 02:33 AM
We are removing the ntp server command from each switch , and also disabling the ntp feature on each switch
06-25-2015 04:20 AM
Ok.
We disabled ntp with the
no ntp feature
command on both switches, and confirmed that ntp is not longer operational, lets hope that will suffice :)
06-29-2015 10:15 AM
We've done the same thing just to make sure. The NTP feature was disabled and will be enabled after that 1st of July. I'll keep you informed on how things went.
06-27-2015 10:51 PM
I don't see this version specifically listed. System version: 5.1(3)N1(1a)
Are we at risk?
06-11-2015 05:53 PM
Since the leap second bug (CSCub38654) is listed as one of the resolved caveats in release notes for 5.2(1)N1(9), it would seem that 5.2(1)N1(8b) would still susceptible to the advisory.
See http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_5_2_1_N1_1/Nexus5000_Release_Notes_5_2_1_N1.html#pgfId-522347.
