10-25-2018 01:18 AM
Hello all,
due to a certain range of SW bugs I am currently updating Nexus 5000 switches.
The update to NX-OS 7.3(3)N1(1) should be without outage (ISSU). The checkups indicate that the update is non-disruptive as well.
Unfortunately, it seems that it comes to connection issues with the fabric path.
Does anyone of you know this kind of issue and a possible solution in administration?
Thank you for your help!
Best regards,
Lukas
Solved! Go to Solution.
10-25-2018 02:08 PM
what is the current version you are upgrading to NX-OS 7.3(3)N1(1)
what features are you using ? how is your setup ? is this vPC or standalone ? any FEX connected ?
if you have any network topo should help us to understand.
10-25-2018 02:08 PM
