Nexus 9300 - %ETHPORT-4-IF_SFP_WARNING: Interface Ethernet1/31, High
sacapano
Hello ,
Is there any bug to fix this problem Nexus 9300 - %ETHPORT-4-IF_SFP_WARNING: Interface Ethernet1/31, High ?
Please
workaround for bug CSCvn85147
take off 1G SFP
Is there a way to find out the 1G SFP?
I check the Ethernet1/31 and its
Ethernet1/31
    transceiver is present
    type is 10Gbase-SR
    name is CISCO-FINISAR
    part number is SFP-10G-SR
OK, it clear not 1G
are the Ver. 9.2(2)?
if not then check this link I think same issue
https://community.cisco.com/t5/server-networking/does-this-mean-a-bad-sfp-module/td-p/3094290
Version is 7.0.3(I7)9 - I also check those link.
