PEAP and WPA Enterprise2 WIFI breaks SPACFG.XML
Travis Ryan
So if you have any of the latest firmwares 7.6.x, maybe others I haven't tested, and use PEAP with WPA2 Enterprise for a wifi profile, you cannot view the /admin/spacfg.xml config.
It will spit out the XML up until the first <profile> tag for the wifi configurations and just die. Won't even put the end tag for the entire document. This presents a huge problem for me as I get and set configurations with this information.
As long as you use PEAP and WPA Enterprise2 (perhaps 1 also) it will kill the xml page. I also cannot import my profiles to the phone via XML when I need this configuration. How can I submit a real bug (bugs website doesn't work well at all this morning, and I don't have a support contract for a simple voip phone)
Travis
Travis Ryan
For anyone interested in the future, I just put in a TAC case. I'm guessing they need to fix this in firmware. I will update as I get more info...
