Change WPA preshare key with Cisco Business Dashboard
suslan
I need to change the SSID's Preshared Key.
I see the SSID in Wireless LANs Discovered in Network, but it only allows me to delete it, not make any kind of modification. The edit symbol does not appear.
What I can do?
Hi suslan,
SSIDs in section "Wireless LANs Discovered in Network" are readonly. If you want to edit SSID, you should create a Wireless LANs profile or edit the existing profile to add a SSID with the same name, then the existing SSID will be replaced by the configuration in profile.
suslan
Hi suslan,
