05-31-2023 05:52 AM
I need to change the SSID's Preshared Key.
I see the SSID in Wireless LANs Discovered in Network, but it only allows me to delete it, not make any kind of modification. The edit symbol does not appear.
What I can do?
Solved! Go to Solution.
05-31-2023 09:41 PM
Hi suslan,
SSIDs in section "Wireless LANs Discovered in Network" are readonly. If you want to edit SSID, you should create a Wireless LANs profile or edit the existing profile to add a SSID with the same name, then the existing SSID will be replaced by the configuration in profile.
05-31-2023 06:24 AM
05-31-2023 09:41 PM
Hi suslan,
