Dashboard 2.2.1.20201105 package issues
michael
I've downloaded both the Dashboard and Probe files for Hyper-V and both contain ubuntu-xenial in the path names inside.
Can't see anywhere else to post this bug so here it is.
David Harper
Hi Michael,
Are you seeing ubuntu-xenial anywhere other than the zip file names and the folders that are created when those are unzipped?  And if not, is this causing any problems or is it just a change that you noticed?  The filename change is deliberate, but if it is causing problems, we can revisit it.
Cheers,
Dave.
Hi Dave
It only causes confusion as I thought it was the wrong files at first.
The VM files inside were accepted by Hyper-V just fine.
Thanks Michael
Ok, thanks.
