Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
470
Damian.m
Beginner
TAGS not working
Hello, when I try to add tag for device I get error like below:
Internal server error : “Unknown modifier: $pushAll. Expected a valid update modifier or pipeline-style update specified as an array; nested exception is com.mongodb.MongoWriteException: Unknown modifier: $pushAll. Expected a valid update modifier or pipeline-style update specified as an array”
It happens when I click save (floppy disk icon), please help in case you know solution.
Cisco Business Dashboard version: 2.3.1.20211011
1 ACCEPTED SOLUTION
David Harper
Hi there,
I just checked with engineering, and it turns out this is a known bug in 2.3.1 and has been fixed in the upcoming 2.4.0 release.  2.4.0 is almost ready to be published, and you should see an upgrade notification in the GUI of your dashboard within a week of the 2.4.0 release.  So it should be visible for you in two to three weeks from now.
Cheers,
Dave.
1 REPLY 1
David Harper
Hi there,
Cheers,
Dave.
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
