12-25-2012 11:16 AM
hello I have a question anyone know sometimes that these certificates of cisco are
CompTIA A+
CompTIA Network+
CompTIA Security+
CompTIA Server+
12-25-2012 11:22 AM
None of these are Cisco certs, Cisco certs always start with Cisco certified I .e. ccie, ccnp, ccna, etc.
Chris
12-25-2012 11:33 AM
Also it essentials?
12-26-2012 08:01 AM
Not sure if I follow, are you asking if you need the CompTIA certs in order to get Cisco certs, if so the answer is no there is not relationship between them.
HTH, please rate all useful posts!
Chris
01-24-2013 04:58 AM
These are part of the CNAP(Cisco Network Academy Program)
ITE 1 takes content from A+
ITE 2 ( discontinued) takes content from Security+, Linux+, Network+
After completing the academy program you get a certificate from the Academy you were enrolled in.
However, none of these are industry recognised.
They just enable you to better understand the concept should you decide to sit for the CompTIA exams.
Or else offer an escalation path to CNAP CCNA Discovery/Exploration program.
Yet, your best bet is to go to a CLP (Cisco Learning Partner) and enroll for a full-blown CCNA program (640-802)
01-24-2013 05:02 AM
I have a question anyone know what routers and switches that are used for CCENT / CCNA CCNP CCNA Security cisco voip ?
01-24-2013 05:05 AM
Check this out.
https://learningnetwork.cisco.com/thread/46993
If remote labs are an option, here's below:
Please rate post if useful.
03-13-2013 03:48 PM
Personally if you want to do Cisco; do Cisco. You won’t get better certifications anywhere else.
