11-27-2019 06:24 AM
Can i anybody help me
179. Which two statements about single and dual homed links are true? (choose two)
Solved! Go to Solution.
11-27-2019 01:45 PM
CCNA 200-125 exam version 4/2019, isn't it ? Moreover poorly copied as you concatenated (d) and (e) answer into one.
OK. I'm not willing to answer yours exam question, but I will try to help you to answer them.
Single homed connection mean there's one (single) uplink only. All packets have no choice but pass this link. One link, one target - static default route (gateway of last resort in Cisco's terminology) is enough for it. Dynamic routing protocols can be used, but it's overkill in typical case.
Dual/multi-homed connections have two or more uplinks. Outgoing packet needs to pass the appropriate one of them. While static routes may fit most simple use cases, dynamic routing is required for most typical case.
If there are multiple links from single provider, an IGP (Interior Gateway Protocol) will be used to setup routes (but EGP - Exterior Gateway Protocol - can be used too).
Uplinks from multiple provides forces use of EGP kind of routing protocol.
Now you know all facts necessary to answer the question.
By the way, CCNA related questions are better to ask in appropriate community of learningnetwork.cisco.com
11-27-2019 01:45 PM
