RV340 Trouble port forwarding multiple devices
e.faig
I need to port forward 2 CCTV servers, I have set the Services up and only 1 (.150) works. Below are screen shots of the config. When I try to set the 2nd (.120) to WAN1 the window goes red and will not save. Its probably something simple but I can't figure it out. Any help will be very appreciated.
E.FAIG
nagrajk1969
hi
post the screenshot when it shows red...
the second port forward rule you are using cctv-8002 right?
