AP Power save with Cisco DNAC
Mani G
Is there any chance to configure AP power save at off-peak hours through Cisco DNA Center.If yes, is it possible in Assurance or Automation ?
Thanks in advance
Hello!
Yes it is possible. But in the newest version of DNA 2.3.X.
You can configure it under Design -> Network settings -> Wireless -> AP Power Profile.
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-3-5/user_guide/b_cisco_dna_center_ug_2_3_5/m_configure-network-settings.html#create-an-ap-power-profile
BR
****Kindly rate all useful posts*****
Hello!
BR
Hey Hi !!!
Thanks, I will try in lab environment and will update.
balaji.bandi
Apart from DNAC, the AP and Controller should be running IOS XE 17.10.X and above.
BB
