Catalyst-Center Console Connection Problems
Paul-Nuttall1
Hopefully someone can help me out hear.
I am having Problem getting the Console Port to work correctly.
The DNA is connected to a Avocent Terminal Server. The Problem is that it is not connecting correctly. I just see Lines.
Does anyone have any Ideas.
Thanks in advance.
balaji.bandi
how about you use Laptop and connect to same console is that works as expected ?
BB
maflesch
Is there a particular reason why we are not utilizing the Cisco IMC portal for console access?
