11-17-2024 06:53 PM
Thank you for your supports.
We are planning to propose Catalyst Center.
The installation guide states that the Enterprise port must be set, but is it necessary to use a 10G port for communication with the managed device?
Is it possible to monitor using a 1G port only such as the Internet port without using a 10G enterprise port?
Regards.
11-17-2024 07:29 PM
What are the end points (and quantity) going to be on-boarded to DNAC?
11-17-2024 08:06 PM
Thank you for your response.
We are planing to install DN2-HW-APL or DN3-HW-APL.
They have following interfaces.
-10 Gbps enterprise portx 2
-10 Gbps cluster x 2
-10 Gbps manament port
-1 Gbps RJ45 management port
-10 Gbps internet port
-1 Gbps RJ45 internet port
-1 Gbps RJ45 CIMC port
11-17-2024 09:01 PM
You are not answering any of my questions.
11-17-2024 09:59 PM
Our end point up to 1,000.
11-17-2024 10:24 PM - edited 11-17-2024 10:28 PM
Enterprise port will only support 10 Gbps -- Insert an SFP and the port will not work plus a loopback plug won't even trigger anything.
Configure the Appliance Using the Maglev Wizard, Step 9 states:
The wizard first presents the 10-Gbps Enterprise port as NETWORK ADAPTER #1.
