Cisco Catalyst 9300 Series Switches eWLC in DNA-C
Jay233
Hi All,
I have a pair of physical 9800 WLC's which have been added to DNA-C (fabric wireless)  - - All good.
I now have enabled eWLC on a 9300 switch (FiaB), the switch is shown in DNA-C as C9300L-48UXG-4X but with and additional message "Wireless Enabled" opposed to WLC Capable. Is there any additional config/process to add the eWLC in as a separate component? Seems odd not to be able to manage it as a normal 9800 WLC.
Example - Inventory>filter>device family is wireless controller only shows the physical WLC and not the eWLC?
Cheers,
marce1000
 - Check this thread for hints : https://community.cisco.com/t5/software-defined-access-sd/cisco-dna-center-enable-embedded-wireless-controller-on-catalyst/td-p/4137966
 M.
