Cisco DNA center provisioning devices
nathanmonteyne0
Hi All,
So currently in DNA center I have the following setup as area
country > area > building > floor
I was told that I need to select the correct floor when doing LAN automation so the switch is already assigned to that floor and that the principel IP address pool in LAN automation is correctly filled in.
now I noticed during the provisioning when it is added to the inventory I can change that field.
i pointed at the field that i mention
After adding it in the fabric I noticed that this isn't possible. Can I assume that I can still change the floor/area etc before I add it to the fabric. If so it would make my life a whole lot easier then just starting LAN automation for 1 switch when I can just start it for 10 and change it afterwards.
balaji.bandi
one of the testing i have done, if you like to move from different location, you need to remove from Fabird and re-provision should work.
there is some order of operation need to be done to move to different floor.
BB
