DNA Center integration with Cisco Spaces
mohamed_afarrag
I'm trying to integrate between DNA Center and Cisco Spaces, after copying the token from cisco spaces and try to paste it on DNA Center the below error message appear on DNA Center
failed to validate Cisco Spaces Certificate, Please check the requisite Cisco Spaces root CA Certificate is added in System > Settings > Trustpool
maflesch
Hi Mohamed. What version of Catalyst Center (Cisco DNA Center) and Cisco Spaces are you using? Also, you may need to export the Cisco Spaces Root CA and manually import it into the Catalyst Center trustpool via the GUI under Menu -> System -> Settings -> Trustpool
