We have an SDA network being configured and setup by another contractor. As sites get migrated to our control we are using a new Network profile with a different set of templates under a different project. The old templates are no longer applied to the new network profile. Our problem is that when we migrate the devices to the new profile and reprovision them with the new templates, they are showing as non-compliant for checks that apply to the old templates that are no longer associated with the device. The old templates are still in use by the contractor for the next sites they are setting up so we cannot delete them. Has anyone found a workaround or solution to this other then completely removing the entire site from inventory and readding them? We are running version 2.3.3.7-72328 as an offline deployment. DNA is still technically under the contractor's account so I figured I'd check here before getting them to open a TAC case.
