DNAC MNEMONIC
ThorMarcos
Hi guys do we have a DNAC MNEMONIC DATABASE for events? I see DNAC generates a lot of events, some are self-explanatory, others aren't it would be helpful for us clients if we were able to know exactly what it means. I had a case when two switches went off because of Power on reason, one was alerted as unreachable and the other one just generated one event SYS:Restart, I wanted to know why this behavior. What could explain it?
pieterh
are you sure these are DNA mnemonics ?
take a closer look it might just be the syslog messages c.q. snmp-traps sent from the devices that are collected by DNAC / Catalyst center.
if this is the case than the message can be  vendor or device-family specific.
You are right, it was a SYS:Restart from the switch which is a Catalyst 9300, but I still want to know why it gave only the SYS: Restart log in this case, when it went off due to power outage, the other one didn't gave it.
