04-01-2025 02:00 AM - edited 04-01-2025 02:08 AM
I have a Catalyst Centre (2.3.7.x) with the following configuration:
1 Node Cluster
Enterprise Interface: 10.10.10.146/29 VIP:10.10.10.150 static route 10.0.0.0/255.0.0.0/10.10.10.145 (Used for bulk communication of Catalysts Centre) where 10.10.10.145 is the default gateway
Internet Interface: 10.10.10.138/29 DG:10.10.10.137 VIP:10.10.10.140 (Used mainly for internet communication with cisco.com)
Management Interface: 10.10.10.131/29 VIP:10.10.10.130 static route 172.10.10.0/255.255.255.0/10.10.10.145 (Used by 3rd party management and API platforms) where 10.10.10.129 is the default gateway
During the deployment the client requested the management interface to change as follows:
Management Interface: 192.168.10.21/24 VIP:192.168.10.20 static route 172.10.10.0/255.255.255.0/192.168.10.1 (Used by 3rd party management and API platforms) where 192.168.10.1 is the default gateway (Changed using maglev-configuration wizard)
We now want to enable management of the CIMC interface through the Catalyst Centre.
04-01-2025 03:34 AM
Interface selection is based on the routing table for the Cat-C appliance. If you wish to route that traffic through the management interface you simply add a route for the CIMC address through the gateway in the management network, the same goes if you want it to go out the enterprise interface. If the CIMC is in the same network as the management interface yout Cat-C will always use the management interface for connectivity.
04-01-2025 05:01 AM
Thanks for the response....the routing is working, if I do a traceroute in the CLI to the CIMC interface IP, traffic is forwarded to the Enterprise Interface default gateway, which is correct.
When I try to enable manage the CIMC using the Catalyst Centre (go System->Settings->System Health) the Catalyst Centre by default add the previous Management as the Catalyst Center Address. I cannot delete the entry and I cannot add an entry to use the Enterprise Interface instead
04-01-2025 11:05 AM
That's because that's the route that the API has defined as the port that communicates to the Cisco IMC address. You can also test this by going to the CLI of the Catalyst Center and issuing this command:
ip route get <CIMC address>
04-02-2025 01:47 AM - edited 04-02-2025 06:26 AM
Thank you for the clarification. Can I change it to use the Enterprise Interface instead
I ran the command and the route sends traffic for the CIMC interface to the Enterprise Interface default gateway.
The problem is adding the CIMC in the Catalyst Center (System->Settings->System Health) to manage the Catalyst Center hardware from the Catalyst Center. I cannot delete the current entry and I cannot change the Catalyst Center Address. which is still the old Management IP Address (10.10.10.131)
04-02-2025 06:48 AM
