Help with a Catalyst 3560 Switch
JALaramie
I bought a used Catalyst 3560 thinking I could configure it like any other router or modem. Boy was I wrong. The graphic tools are no longer available and it appears they wouldn't run on my Linux laptop anyway. I have command line access and have attempted some configuration.
I have a single fixed IP for outside access. I wish to use NAT to give local hosts internet access. Some of my hosts will have static local IPs and others will use dynamic addresses. I've configured a DHCP pool but I don't know how to get the switch to use it to assign addresses. I've given the switch a temporary local IP so that I can configure it.
I'm attaching my configuration printout. Sorry to bother with such a basic problem but I would appreciate any help offered.
Jeff
balaji.bandi
This switch does not do NAT, so (if the vendor offers a return, return this and ask for a Router with some LAN ports)
Or you can build any OLD PC as Linux router(that act as NAT and FW)  and connect to the internet and use switch in LAN
BB
balaji.bandi
BB
