How to find DNAC hostname from web GUI?
jaheshkhan
Level 5
Level 5
I searched a lot but cannot find it
marce1000
            - What's the GUI-url you are using ?
 M.
balaji.bandi
depends how you have setup, most cases use IP address for clustering,. is this cluster or signle node.
you will see more informaion of each node in cluster ----system--> disaster recovery.
check below guide of setup guide :
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-2-2/install_guide/2ndgen/b_cisco_dna_center_install_guide_2_2_2_2ndGen/m_prepare_the_appliance_for_configuration_2_2_2_2ndgen.html
BB
rasmus.elmholt
Level 7
Level 7
You can take a look at the SAN field in the Certificate on the DNAC.
Or look in the system health.
