Maglev cli
KevinR99
Has anything changed with DNAC and maglev commands?  I’ve not logged into the cli on our DNAC for some time and we have had several updates since.  We are at the latest version currently.  Yesterday I had an issue and wanted to run a tcpdump.  So I looked at my notes and got the commands
sudo tcpdump ……..
When I tried this it was an unrecognised command.  I’m certain I’ve run tcpdump before from the maglev cli.
Thanks, Kev
willwetherman
This will be caused by the restricted shell feature that is enabled by default in the later versions of DNA Center
When you SSH to maglev, you need to enter command '_shell' to enter the bash shell to be able to run commands such as tcpdump.
You can disable and re-enable the restricted shell feature if required
To disable
_shell -c 'sudo magctl ssh shell bash'
To re-enable
_shell -c 'sudo magctl ssh shell magshell'
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-3-3/admin_guide/b_cisco_dna_center_admin_guide_2_3_3/b_cisco_dna_center_admin_guide_2_3_3_chapter_010.html#Cisco_Task_in_List_GUI.dita_54088...
7 Replies 7
marce1000
 - If possible search for the command with Linux find , it may not be included in the PATH of the current user.
 M.
willwetherman
To disable
To re-enable
I was a little fast and typed only:
_shell
Now DNAC want to know the Challenge / Response Token. How can a clear that state?
$ _shell -c 'sudo magctl ssh shell magshell'
A challenge is already in progress with state CT_STATE_RESP_WAIT
VunL3QAAAQUBAAQAAA.....
Please provide the consent token via [_shell -v] command for bash shell-access
Martin
Martin, you need to get onto TAC for a token.
Check the admin guide.
Hope that helps.
Regards.
Hey @Martin Grimm , i stumpled about the same issue. Were you able to solve it?
Hi Cedric, yes you need a TAC Case, for that.
KevinR99
Thank you.  That worked.
