PnP with C1121X-8P and Catalyst Center
Herbert Dinnobl
Is it possible?
The PnP Discovery is sucuessful on Router, but the device not appear in Catalyst Center to claim...
You need to send the device ready.
If you buy It from  cisco representative and you tell them you need dnac license, Cisco will send the device to you with license installed.
This time you need to get remote access to the device and install It.
7 Replies 7
@Herbert Dinnobl
Do you have DNAC license on the device?
no, and it is not possible to activate DNA License
Router(config)#license boot level ?
appxk9 Appx License Level
securityk9 Security License Level
uck9 Unified Communication License Level
It is not that simple.
Which IOS version do you have on this router?
Herbert Dinnobl
Cisco IOS XE Software, Version 17.09.05a
Device is compatible with DNAC but you need to buy DNAC license to install on the device. This can be done via smart license or by other means. Contact a cisco reseller in your place, they will give you direction.
Correct, but then i can not use PnP, because the devices are already delivered. If i use smart licensing the i have to configure the device manually. Or do you know another way?
Thank for your input in advance
