Problem creating SGT in DNAC
e-chuah
I am having problem creating SGT in DNAC. It was working previously.
DNAC and ISE integration status is ok.
I get the errors (see attached screenshot) when creating SGT in DNAC.
com.cisco.cpm.nsf.api.exceptions.NSFEntitySaveFailed:
org.hibernate.exception.Generic JDBCException: Could not prepare statement
Not sure if anyone has encountered this error before.
Rgds
Eng Wee
seems like internal issue. better open a TAC case.
Good luck
KB
willwetherman
I had this issue before which was caused by a bug in ISE. An upgrade to 2.7 patch 4 as detailed in the bug resolved it for me.
There is a temporary workaround detailed in the bug description, however I didn't try this so not sure if it works or not
https://bst.cisco.com/bugsearch/bug/CSCvv29737
Hope that this helps
