Question on Catalyst Center and API
econstas
I am trying to figure out how to get the Token for Cat Center 2.3.7.6.  Is it the call to get a Token that's active for 1hr and then use it to make other requests? Or is there a place to get a token attached to my id? I have been looking for the ID option, but no luck.
Can you assist because I have also tried the generate token via a call but it seems to not be working right now. Any assistance will be helpful.
2 Accepted Solutions
DanielP211
Hello!
To get the token you have to make an POST request to /dna/system/api/v1/auth/token with username/password. The token is valid for 60minutes. What is the API call you tried to make?
BR
****Kindly rate all useful posts*****
Torbjørn
The "getting started" section of the API documentation is a good place to start. https://developer.cisco.com/docs/dna-center/getting-started/
If you are still having issues, verify if AES encryption is enabled under "System > Settings > Authentication API Encryption". If so, you should see this part of the API Docs and will need a valid key.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
DanielP211
Hello!
BR
Torbjørn
