Reset Cisco 9300
ahmedmaged9432
need to reset switch Cisco 9300 to factory settings but i press the mode bottom when plug it in power and waited till i enter the enable mode in the switch and  nothing is happen , is there is steps to do reset
ChuckMcF
REF: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-11/configuration_guide/sys_mgmt/b_1611_sys_mgmt_9300_cg/simplified_factory_reset.html
Please read the document above thoroughly before issuing this command to ensure you understand the impact prior to executing.
enable
factory-reset config
HTH,
Chuck McFadden
--Please mark helpful posts as helpful--
