Sg550x 1 Vlan accross 4 Switches PXE Boot
Vanitas
i have changed the vlan, so that every room in the same building with only 1 pc has the same vlan 500 and the rooms with more then 1 pc gets there own vlan (room number), but the problem now is that we cant PXE Boot on every switch in Vlan 500, we use Static routes from location distributor to the building distributor to the floor distributor, i can ping the WDS from the Building distributor but with the floor distrubutor i cant ping the WDS.
DHCP 172.16.242.167  WDS 172.16.242.163 option 66 and 67 are enabled, i dont use UDP Relay/IP Helper.
Vanitas
0 Replies 0
