03-31-2025 10:20 PM
If i buy more cisco catalyst same model and i bought subscription for support and update just for one of them, cand i upgrade the firmware and things with it ? like its same model. I use them in a intern network withof internet.
Thanks for help
03-31-2025 11:38 PM
If this is for a lab purposes it is probably fine, but check with your Cisco AM if this is for anything else than a temporary lab environment. You will be able to download software but you won't be able to raise TAC cases on the one without a service agreement.
04-01-2025 01:54 AM
I believe the legal answer is no.
