Where Can I find Interfaces info in Catalyst Center?
MuathA.
I have access to the GUI and CLI of Cisco Catalyst Center, but I don’t know how to find Interface info like MAC addresses and installed SFP … this is for the catalyst center server itself.
From CIMC I can see the network adapters and their MACs.. I just want to know where I would find interface related info in the catalyst center
balaji.bandi
The catalyst center (aka DNAC) is custom-based and built on top of Linux so you can view it from the command level.
You can use the following from CLI:
$ ip a | egrep "management"
$ ip a | egrep "internet"
$ ip a | egrep "cluster"
$ ip a | egrep "enterprise"
Note : recent version locked shell for advanced usage so you need TAC.
BB
Tomas de Leon
Here is as an easy solution for getting IP address and mac addresses for Catalyst Center interfaces without the need to open a Cisco TAC Case.
  1. ssh maglev@{catc.ip.address} -p 2222
  2. run cli command, " ip a "
  3. copy & paste display output to a text file on your laptop/desktop (ie. catc-notes_01.txt)
  4. run command string to reference the saved file on your laptop/desktop.
    For example, cat catc-notes_01.txt | egrep -A1 "enp|eno|management|internet|cluster|enterprise"
Example of Output:
$ cat catc-notes_01.txt | egrep -A1 "enp|eno|management|internet|cluster|enterprise"
2: enp69s0f0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master enterprise state UP group default qlen 1000
link/ether 3c:fd:fe:e4:6a:14 brd ff:ff:ff:ff:ff:ff
3: enp69s0f1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master cluster state UP group default qlen 1000
link/ether 3c:fd:fe:e4:6a:15 brd ff:ff:ff:ff:ff:ff
4: enp237s0f0: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master management state DOWN group default qlen 1000
link/ether 2c:f8:9b:28:fa:4e brd ff:ff:ff:ff:ff:ff
5: enp237s0f1: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master internet state DOWN group default qlen 1000
link/ether 2c:f8:9b:28:fa:4f brd ff:ff:ff:ff:ff:ff
6: enp237s0f2: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master enterprise state DOWN group default qlen 1000
7: enp237s0f3: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master cluster state DOWN group default qlen 1000
8: enp53s0f0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master management state UP group default qlen 1000
9: enp53s0f1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master internet state UP group default qlen 1000
10: management: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.2.207/24 brd 172.18.217.255 scope global management
valid_lft forever preferred_lft forever
inet 192.168.2.208/32 scope global management
11: internet: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.1.207/24 brd 172.18.242.255 scope global internet
inet 192.168.1.208/32 scope global internet
12: enterprise: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.211.207/24 brd 192.168.211.255 scope global enterprise
inet 192.168.211.208/32 scope global enterprise
13: cluster: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 1.1.1.207/24 brd 1.1.1.255 scope global cluster
inet 1.1.1.208/32 scope global cluster
