03-04-2025 09:56 AM
I have access to the GUI and CLI of Cisco Catalyst Center, but I don’t know how to find Interface info like MAC addresses and installed SFP … this is for the catalyst center server itself.
From CIMC I can see the network adapters and their MACs.. I just want to know where I would find interface related info in the catalyst center
03-04-2025 11:50 PM
The catalyst center (aka DNAC) is custom-based and built on top of Linux so you can view it from the command level.
You can use the following from CLI:
$ ip a | egrep "management"
$ ip a | egrep "internet"
$ ip a | egrep "cluster"
$ ip a | egrep "enterprise"
Note : recent version locked shell for advanced usage so you need TAC.
03-05-2025 07:24 AM
Here is as an easy solution for getting IP address and mac addresses for Catalyst Center interfaces without the need to open a Cisco TAC Case.
Example of Output:
$ cat catc-notes_01.txt | egrep -A1 "enp|eno|management|internet|cluster|enterprise"
2: enp69s0f0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master enterprise state UP group default qlen 1000
link/ether 3c:fd:fe:e4:6a:14 brd ff:ff:ff:ff:ff:ff
3: enp69s0f1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master cluster state UP group default qlen 1000
link/ether 3c:fd:fe:e4:6a:15 brd ff:ff:ff:ff:ff:ff
4: enp237s0f0: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master management state DOWN group default qlen 1000
link/ether 2c:f8:9b:28:fa:4e brd ff:ff:ff:ff:ff:ff
5: enp237s0f1: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master internet state DOWN group default qlen 1000
link/ether 2c:f8:9b:28:fa:4f brd ff:ff:ff:ff:ff:ff
6: enp237s0f2: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master enterprise state DOWN group default qlen 1000
7: enp237s0f3: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master cluster state DOWN group default qlen 1000
8: enp53s0f0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master management state UP group default qlen 1000
9: enp53s0f1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master internet state UP group default qlen 1000
10: management: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.2.207/24 brd 172.18.217.255 scope global management
valid_lft forever preferred_lft forever
inet 192.168.2.208/32 scope global management
11: internet: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.1.207/24 brd 172.18.242.255 scope global internet
inet 192.168.1.208/32 scope global internet
12: enterprise: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.211.207/24 brd 192.168.211.255 scope global enterprise
inet 192.168.211.208/32 scope global enterprise
13: cluster: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 1.1.1.207/24 brd 1.1.1.255 scope global cluster
inet 1.1.1.208/32 scope global cluster
