07-07-2016 01:29 PM
In the feature guide, it shows a keyboard shortcut for Full Screen:
Shift-F / F11 / CTRL-Command-F Toggle Fullscreen (All Platforms / Windows / OS X)
I'm running Win10, and F11 doesn't work for me (or Shift-F). When I hit F11, it enters the following in the console:
Any ideas?
Solved! Go to Solution.
07-07-2016 02:06 PM
Hi Mike,
Can you please make sure you click away from the console window and double click the edge of the app? Then try full-screen screen shortcut.
John
07-07-2016 02:06 PM
Hi Mike,
John
07-07-2016 02:36 PM
Looks like that did it. It's hard to make it focus on the border.
Thanks for the help.
