Confusing jumbled up navigation lists.
g1smdvoip
Level 3
Level 3
The navigation list on the left of the following page is a confusing mess...
http://www.cisco.com/cisco/software/release.html?mdfid=278719042&release=3.1.19-NZ&catid=278875240&softwareid=282074292&os=Linux
with  a crazy non-sorted order (prefix all with 3.1.):
9, 8, 7, 6, 5, 4, 3,  13, 3, 20, 2, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 1.
New files  appear in the middle of the list. Eh? That is not at all intuitive.
A leading zero on the final part when it's a single digit would fix this; i.e. name files like 3.1.02 with a leading zero instead of 3.1.2 so that   they stand some chance of being listed in numerical order in the   navigation menu.
41 Replies 41
This has been fixed.
g1smdvoip
Level 3
Level 3
http://www.cisco.com/cisco/software/release.html?mdfid=278719042&release=3.1.9-CN&catid=278875240&softwareid=282074292&os=Linux
http://www.cisco.com/web/software/282074292/48520/dp-ffr-3-1-9-CNNP_Readme.txt
This is the file for China.
Why does the DIALPLAN RELEASE RELATED DEFECT DESCRIPTION section list defects in the GB dial plan?
Why does the RELATED DOCUMENTATION section link to
http://en.wikipedia.org/wiki/Telephone_numbers_in_Croatia
http://www.itu.int/oth/T0202000032/en (Croatia)
Why does the PREVIOUS RELEASE INFORMATION section list previous releases for Croatia and not China?
This is fixed.
g1smdvoip
Level 3
Level 3
http://www.cisco.com/cisco/software/release.html?mdfid=278719042&release=3.1.13-GB&catid=278875240&softwareid=282074292&os=Linux
http://www.cisco.com/web/software/282074292/30421/dp-ffr-3-1-13_GBNP_Readme.txt
This is the file for GB.
DIALPLAN RELEASE RELATED DEFECT DESCRIPTION refers to defects in Swiss and Netherlands dial plans.
PREVIOUS RELEASE INFORMATION refers to previous releases of New Zealand software.
This is fixed.
g1smdvoip
Level 3
Level 3
Thank you for the detailed feedback.
We have the team looking at these problems now.  Since that team doesn't monitor the support forums as a matter of course, you will have better luck using the "Feedback" link on the "Download Software" page:
We apologize for the inconvenience, and appreciate the time you have taken to detail the problems with the software download page.
Thanks for finding the right people and passing the message on.
Yes, GB version 17 is now in the correct folder.
Of course, GB version 7 is still nowhere to be seen as
http://www.cisco.com/cisco/software/release.html?mdfid=278719042&softwareid=282074292&release=3.1.7-GB&os=Linux
is now empty.
is now empty.
g1smdvoip
Level 3
Level 3
The navigation list is a complete mess.
How about changing to...
"3.1.X-CH"  - with versions 3.1.1 to 3.1.9 for CH inside.
"3.1.X-CN"  - with versions 3.1.1 to 3.1.9 for CN inside.
"3.1.X-CT"  - with versions 3.1.1 to 3.1.9 for CT inside.
"3.1.X-ES"  - with versions 3.1.1 to 3.1.9 for ES inside.
"3.1.X-GB"  - with versions 3.1.1 to 3.1.9 for GB inside.
"3.1.X-IN"    - with versions 3.1.1 to 3.1.9 for IN inside.
"3.1.X-NZ"   - with versions 3.1.1 to 3.1.9 for NZ inside.
"3.1.X-PT"   - with versions 3.1.1 to 3.1.9 for PT inside.
"3.1.1X-CT"  - with versions 3.1.10 to 3.1.19 for CT inside.
"3.1.1X-GB" - with versions 3.1.10 to 3.1.19 for GB inside.
"3.1.1X-NZ"  - with versions 3.1.10 to 3.1.19 for NZ inside.
"3.1.2X-NZ"  - with versions 3.1.20 to 3.1.29 for NZ inside.
...and so on.
It would at least shrink the navigation list to manageable proportions.
I would suggest also reporting this to the feedback link, with a pointer to this thread and the screenshots.
Done and Done - and a suitable response was received within a matter of hours too.
