New Interface command for connection
georgehendrix
Cisco, I think it would be good to add a new command on routers and switches for the interface connectivity.  Description is good for some things, but I think it would be good to add a second command such as "patch-number" or something like that.  This would allow you to put a description of the device connected using the description command, while the new command would allow you to include the patch/drop number as well.
0 Replies 0
