09-21-2018 05:22 PM
Hi Team -
I've registered the UCS vcenter plugin and everything seems fine. After restarting the web client service I also see the event logs that shows the process was successful. But in the web client I can not see UCS Plugin icon.
I see the plugin available in the mobi page of vcenter.
https://x.x.x.x/mob/?moid=ExtensionManager
Any help is much appreciated.
09-22-2018 12:15 AM
Can you please share the logs available at the below location:
cd /var/log/vmware/vsphere-client/logs/vsphere_client_virgo.log.
09-23-2018 11:47 PM
Did the installation complete? I had the same problem and however the installation said it was completed there was nothing installed. In my case there was a firewall between the client which ran the installation and vCenter. This firewall blocked the copy traffic.
After running the installation inside the same network everything went fine. At the end I found it out with help of an existing installation. Here the installation files were available. However, on the faulty one the files weren't.
Hopefully this helps.
Eelco
09-24-2018 12:21 PM
I'll try and update you tomorrow. Thanks for the reply.
