"Get-UcsNetworkLanNeighborEntry" doesn't work for breakout ports
zwphoenix
Beginner
Beginner
I have 6332 FIs and network uplink is 40 Gbps ports that configured as breakout ports and connected 1 of the 4 ports to 10 Gbps upstream port on Cisco 7K switches.
I'm able to show cdp neighbor by SSH. But cannot get any output by PowerTool command Get-UcsNetworkLanNeighborEntry.
Same command works fine on 6200 FIs 10 Gbps uplinks. Does anybody see same issue like my case? Is it a bug?
mojafri
Could you please verify if "Info Policy" is enabled?
Enabling the Information Policy via UCSM GUI.
  • Go to “Equipment” -> “Policies” tab -> “Global Policies” tab -> “Info Policy” area.
  • Change to “Enabled
Please vote if this helps.
MJ
Recognize Your Peers
