jasonsha
Level 5
Level 5
This is a script to backup, remove and restore NTP configurations on one or many UCS Domains.
Note: Removing the NTP configurations may be recommended prior to the upcoming June 30, 2015 “leap second” event, in order to prevent undesired process crashes in exposed NTP implementations.
For more Information:
http://www.cisco.com/web/about/doing_business/leap-second.html
https://tools.cisco.com/bugsearch/bug/CSCus83447
REQUIRES:   PowerShell Version 3
See attached README Doc for full details.
AristizabalC
Community Member
Works great, I have 9 UCS domains and this saves me a lot of time. Thanks.
joshua.barton
Community Member
Awesome! The only issue I had is apparently $env:PowerToolInstallPathCiscoUcsPS is null on the system where I have CiscoUcsPs installed. "Import-module CiscoUcsPs" seems to work fine for me, though. After I manually loaded that it ran without any issue. Saved me a lot of time
Thanks!
