Python SDK for Cisco UCS Central
- Apache License, Version 2.0 (the "License")
Installation
From github:
Installs the latest top of the tree development version,
# Install pip (skip if pip is already available):
wget https://bootstrap.pypa.io/get-pip.py
python get-pip.py
git clone https://github.com/CiscoUcs/ucscsdk.git
cd ucscsdk
make install
From pip:
pip install ucscsdk
Community:
- We are on Slack - slack requires registration, but the ucspython team is open invitation to anyone to register here
History
0.9.0.1 (2018-04-26)
- Support UCS Central release 2.0(1d)
- Adding test infra with parameters from config file to be used for sanity
- Fix for the issue where None values are compared for validation of property
0.9.0.0 (2016-11-14)
- Python SDK for UCS Central management and related automation
- Supports every Managed Object exposed by UCS Central
- APIs for CRUD operations
- Support for UCS Central and domain backup, export/import configuration
- Support for firmware management and tech-support
- Support for UCS Domain management
- Support for server side filters
- Support for UCS Central eventhandlers
- Logging support
- Nosetests for unit testing
- Integrating the sphinx framework for documentation
- PEP8 Compliance
